Hello, I need help with my Refig. Model 59675239400. The compressor will come on for a few seconds, then shut off. Then a few minutes later the compressor will come on and then shut off again. I have 124V at the capacitor. I replaced the compressor starting device and defrost thermostat. The compressor/motor winding checked out OK. Both fans are running and control damper is working. Could this be the control board and is there a way to check the board? Or could the compressor be locked up? Thanks Chuck
[COLOR="Blue"]Could this be the control board and is there a way to check the board?[/COLOR] No the board is OK because you are getting the correct voltage across the compressor.
[COLOR="Blue"] Or could the compressor be locked up?[/COLOR] Yes that is what it sounds like.
Could be the capacitor but when I looked up the start relay it showed that the capacitor is part of the relay replacement. |
THIS FORUM IS DEAD!!!!!!! |
