open
#1 Posted : Wednesday, July 17, 2013 8:30:00 AM(UTC)
open
Hello, I need help with my Refig. Model 59675239400. The compressor will come on for a few seconds, then shut off. Then a few minutes later the compressor will come on and then shut off again. I have 124V at the capacitor.
I replaced the compressor starting device and defrost thermostat. The compressor/motor winding checked out OK. Both fans are running and control damper is working. Could this be the control board and is there a way to check the board? Or could the compressor be locked up? Thanks Chuck
#2 Posted : Thursday, July 18, 2013 3:43:53 AM(UTC)
[COLOR="Blue"]Could this be the control board and is there a way to check the board?[/COLOR]
No the board is OK because you are getting the correct voltage across the compressor.
[COLOR="Blue"] Or could the compressor be locked up?[/COLOR]
Yes that is what it sounds like.
Could be the capacitor but when I looked up the start relay it showed that the capacitor is part of the relay replacement.
Fridge compressor not staying on (Refrigerator & Freezer Repair)
by craigd 10/29/2011 10:23:16 AM(UTC)
Compressor not staying on (Refrigerator & Freezer Repair)
by cushionhead 7/22/2011 6:58:46 PM(UTC)
