forenz
#1 Posted : 12 years ago
forenz
Dryer timer is running when start button is pressed, and door starts and stops the timer, but dry drum and heating element are not initiated. Can you suggest a part replacement or suggested repair solution?
#2 Posted : 12 years ago
Parts for Whirlpool LE7800XSN2 Dryer - AppliancePartsPros.com
Could be that the thermal fuse on the blower wheel (Item 7 in Bulkhead Parts section) has blown.
Unplug the unit and check the fuse with a meter should be 0 ohms.
Jiggery Pokery method is.
Unplug the unit.
Remove both wires from the fuse, short them together and tape them up so they will not short to the frame.
Plug the unit in and give it a try.
If blown, replace the fuse ASAP as it is a critical safety device re: prevents lint fires which can turn into house fires.
Also clean/check your vent system and the blower as these are the most common causes of it blowing.
forenz
#3 Posted : 12 years ago
forenz
Thanks Denman I discovered that yes my thermal fuse was blown through a Whirlpool repair youtube video and I have replaced it through my local appliance parts shop and the dryer is back in service.
Forenz
Maytag gas dryer problem with model MDG5500AWW (Dryer Repair)
by Guest 2 years ago
Front load dryer problem (Dryer Repair)
by Guest 4 years ago
Kenmore dryer problems after replace drum belt/idler pulley (Dryer Repair)
by Hspot 4 years ago
Dryer problem (Dryer Repair)
by johnh@echoetching.com 7 years ago
by al kopsick 8 years ago
Cabrio dryer problems (Dryer Repair)
by artsalena 8 years ago
Dryer Problem (Dryer Repair)
by clcw199 9 years ago
Need help narrowing dryer problem.... (Dryer Repair)
by blkhwks19 9 years ago
by gtravis331 11 years ago
by Qzzy 11 years ago
clothes dryer problem (Dryer Repair)
by jsullivan652 11 years ago
Dryer Problem - Fuse Blowing (Dryer Repair)
by ppp2000 11 years ago
by Pat Ranguette 12 years ago
by Hoovdawg3 12 years ago
Dryer Problem Again (Dryer Repair)
by dstoliby 13 years ago
