while running it makes a grining sound I opened the top and the belt is still on with good tension.
In order to provide the most accurate advise I need the complete model number of the dryer. You can find it on the door frame.
any advice before i by a new dryer i have been waiting on an update
You have to remove the front panel, the bulkhead front panel and the drum and check all moving parts inside.
Post your findings.
