Grump
#1 Posted : Thursday, June 13, 2013 5:14:09 AM(UTC)
Grump
Had a problem with this dryer back in Jan. Replaced start switch and has been working fine until yesterday. Dryer stopped and will not start. The start switch is okay, according to the ohm test. Any suggestions as to what the problem might be? Thanks to dewman for his advice back in Jan... Grump
Simon / APP Team
#2 Posted : Thursday, June 13, 2013 8:36:58 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
The first thing to check is the power supply. Reset the circuit breaker, check the wall outlet and the power cord.
Next, open the toe panel( with dryer unplugged) and check the continuity of the thermal fuse
Part number: 3390719
located on the top of the blower housing. Remove one wire off the fuse when testing. If there is no continuity, you should replace it and clean the entire air flow system (internally and externally).
Please, post the results.
Simon.
lg dryer will not start (Dryer Repair)
by Guest 8/30/2022 11:16:45 AM(UTC)
Maytag dryer will not start (Dryer Repair)
by Kabel69 10/14/2017 3:03:55 PM(UTC)
Dryer will not start (Maytag MEDC300BW) (Dryer Repair)
by Brad S 9/26/2017 9:12:45 AM(UTC)
by vassarrepair 2/2/2017 6:32:18 AM(UTC)
Gas dryer will not start (Dryer Repair)
by needhelp22 1/11/2016 6:45:33 AM(UTC)
Whirlpool Dryer will not start (Dryer Repair)
by 123zorn 12/3/2015 5:01:02 PM(UTC)
estate dryer will not start! (Dryer Repair)
by robmacdaddy 11/23/2015 7:34:08 AM(UTC)
BRAND NEW kenmore dryer will not start!!! (Dryer Repair)
by clarajj 10/19/2015 5:29:21 AM(UTC)
Dryer will not start. No Display. (Dryer Repair)
by gw2015 8/8/2015 7:45:27 AM(UTC)
Neptune dryer will not start-fuses and door switch works (Dryer Repair)
by Maryland1 1/10/2015 12:02:30 PM(UTC)
Whirlpool Ultimate Care II dryer will not start (Dryer Repair)
by jajinnette 12/14/2014 10:09:44 AM(UTC)
Help! Dryer will not start (Dryer Repair)
by Chrisk4099 12/9/2014 3:07:35 PM(UTC)
Whirlpool Duet Dryer will not start (Dryer Repair)
by brbckg 9/7/2014 4:51:22 PM(UTC)
by saaman 8/21/2014 12:46:47 PM(UTC)
Maytag Dryer will not start... (Dryer Repair)
by robert45 8/8/2014 11:46:53 AM(UTC)
