Had a problem with this dryer back in Jan. Replaced start switch and has been working fine until yesterday. Dryer stopped and will not start. The start switch is okay, according to the ohm test. Any suggestions as to what the problem might be? Thanks to dewman for his advice back in Jan... Grump
Groups: APP Team
Hi. The first thing to check is the power supply. Reset the circuit breaker, check the wall outlet and the power cord. Next, open the toe panel( with dryer unplugged) and check the continuity of the thermal fuse Part number: 3390719
located on the top of the blower housing. Remove one wire off the fuse when testing. If there is no continuity, you should replace it and clean the entire air flow system (internally and externally). Please, post the results. Simon.
