handyexpert
#1 Posted : Saturday, June 1, 2013 7:02:21 AM(UTC)
handyexpert
Everything was fine. Woke up to find nothing cooling in fridge or freezer. No sound. No nothing. Light is on. Thermostat does nothing.
#2 Posted : Sunday, June 2, 2013 2:18:49 AM(UTC)
Parts for Amana ABB2221FEB Refrigerator - AppliancePartsPros.com
How long has it been like this?
Could be that you are in a defrost cycle which will last about half an hour.
Could be that you are stuck in a defrost cycle.
If the unit does not come out of defrost try rotating the defrost timer (Item 3 in Section 03) cam.
It can only be turned in one direction.
Also there is usually a hole in the cover so that you can do this without any dis-assembly.
If the unit fires up replace the timer.
Maytag fridge side not cooling. (Refrigerator & Freezer Repair)
by Ropavejero 6/23/2023 4:37:10 PM(UTC)
maytag fridge doesn't work (Refrigerator & Freezer Repair)
by old fridge 8/31/2020 6:51:57 PM(UTC)
Maytag Fridge PTW1949GRW hot to the touch between fridge and freezer (Refrigerator & Freezer Repair)
by mbarone 2/14/2019 6:08:20 AM(UTC)
MFX2876DRM02 Maytag fridge ice build up (Refrigerator & Freezer Repair)
by HOOBI 11/27/2018 12:09:49 PM(UTC)
Maytag Fridge Buzzing then CLICK (Refrigerator & Freezer Repair)
by eliteconcept 1/17/2017 9:52:03 AM(UTC)
Maytag fridge - Not as cold in freezer and fridge sections (Refrigerator & Freezer Repair)
by tadrian2 7/3/2016 8:54:05 PM(UTC)
MAYTAG fridge not working (Refrigerator & Freezer Repair)
by Ralph Tal 12/28/2014 9:53:06 PM(UTC)
maytag fridge problems (Refrigerator & Freezer Repair)
by BILL 3RD 8/28/2014 8:38:54 PM(UTC)
Maytag fridge / freezer not cold (Refrigerator & Freezer Repair)
by repsolal 8/3/2014 8:27:43 AM(UTC)
Maytag fridge warm, freezer cold (Refrigerator & Freezer Repair)
by ASBIT1983 4/22/2014 7:53:16 AM(UTC)
Maytag Fridge and Freezer not cooling enough (Refrigerator & Freezer Repair)
by richbis 3/27/2014 4:23:35 PM(UTC)
maytag fridge not cooling but freezer is fine (Refrigerator & Freezer Repair)
by jdubstewart 1/5/2014 6:23:09 PM(UTC)
Maytag fridge and freezer not cooling properly (Refrigerator & Freezer Repair)
by elliecats 12/27/2013 9:07:11 AM(UTC)
Maytag fridge clogged drain plug access (Refrigerator & Freezer Repair)
by akbrownings 2/25/2013 2:00:50 PM(UTC)
Maytag fridge warm & no ice build up (Refrigerator & Freezer Repair)
by MikeinDerby 10/31/2012 8:25:15 AM(UTC)
