Everything was fine. Woke up to find nothing cooling in fridge or freezer. No sound. No nothing. Light is on. Thermostat does nothing.
Here are your parts Parts for Amana ABB2221FEB Refrigerator - AppliancePartsPros.comHow long has it been like this? Could be that you are in a defrost cycle which will last about half an hour. Could be that you are stuck in a defrost cycle. If the unit does not come out of defrost try rotating the defrost timer (Item 3 in Section 03) cam. It can only be turned in one direction. Also there is usually a hole in the cover so that you can do this without any dis-assembly. If the unit fires up replace the timer. |
THIS FORUM IS DEAD!!!!!!! |
