handyexpert
#1 Posted : 12 years ago
handyexpert
Everything was fine. Woke up to find nothing cooling in fridge or freezer. No sound. No nothing. Light is on. Thermostat does nothing.
#2 Posted : 12 years ago
Parts for Amana ABB2221FEB Refrigerator - AppliancePartsPros.com
How long has it been like this?
Could be that you are in a defrost cycle which will last about half an hour.
Could be that you are stuck in a defrost cycle.
If the unit does not come out of defrost try rotating the defrost timer (Item 3 in Section 03) cam.
It can only be turned in one direction.
Also there is usually a hole in the cover so that you can do this without any dis-assembly.
If the unit fires up replace the timer.
Maytag fridge side not cooling. (Refrigerator & Freezer Repair)
by Ropavejero 2 years ago
maytag fridge doesn't work (Refrigerator & Freezer Repair)
by old fridge 4 years ago
Maytag Fridge PTW1949GRW hot to the touch between fridge and freezer (Refrigerator & Freezer Repair)
by mbarone 6 years ago
MFX2876DRM02 Maytag fridge ice build up (Refrigerator & Freezer Repair)
by HOOBI 6 years ago
Maytag Fridge Buzzing then CLICK (Refrigerator & Freezer Repair)
by eliteconcept 8 years ago
Maytag fridge - Not as cold in freezer and fridge sections (Refrigerator & Freezer Repair)
by tadrian2 9 years ago
MAYTAG fridge not working (Refrigerator & Freezer Repair)
by Ralph Tal 10 years ago
maytag fridge problems (Refrigerator & Freezer Repair)
by BILL 3RD 10 years ago
Maytag fridge / freezer not cold (Refrigerator & Freezer Repair)
by repsolal 10 years ago
Maytag fridge warm, freezer cold (Refrigerator & Freezer Repair)
by ASBIT1983 11 years ago
Maytag Fridge and Freezer not cooling enough (Refrigerator & Freezer Repair)
by richbis 11 years ago
maytag fridge not cooling but freezer is fine (Refrigerator & Freezer Repair)
by jdubstewart 11 years ago
Maytag fridge and freezer not cooling properly (Refrigerator & Freezer Repair)
by elliecats 11 years ago
Maytag fridge clogged drain plug access (Refrigerator & Freezer Repair)
by akbrownings 12 years ago
Maytag fridge warm & no ice build up (Refrigerator & Freezer Repair)
by MikeinDerby 12 years ago
