Can Not Get Washer Into Test Mode. Is The Control Board Bad. It A Ge Front Load. WBVH5300KOWW
are you unplugging the unit from the wall for 90 seconds? when you restore power you have about 30 seconds to press the buttons in this sequence. signal-delay-signal-delay. also make sure door is shut good. if it still does not work, leave unplugged overnight and try again. if it still does not react, yes, the control is bad
