Hello,
I have a Kenmore side by side Model # 106.50582001. The edge of the door on the freezer side gets hot. Noticed that the fan for the compressor and coils is not working. Placed a fan on the floor ,turned it on low , now the door edge is cool again. Does this mean the fan is bad, or the thermostat ? And how would I check this problem out?
Thank you for any info
Chris:confused:
Read more: http://forum.appliancepartspros...post242231#ixzz0uBEItM5w http://forum.appliancepartspros.com
Hello Chris, The condenser fan motor (next to the compressor) is bad and has to be replaced. No doubt about it. - The condenser fan motor Part number: AP3133080
Originally Posted by: Gene  Hello Chris, The condenser fan motor (next to the compressor) is bad and has to be replaced. No doubt about it. - The condenser fan motor Part number: AP3133080
Gene. Thank you Gene, I'll see what I can do to find and replace it. I will let you know how it goes! Thanks again, Chris :)
Originally Posted by: Chris A  Thank you Gene, I'll see what I can do to find and replace it. I will let you know how it goes!
Thanks again, Chris :) Chris, It's very easy to find it - just click on the picture. :) Gene.
Gene. It says their out of stock!:(
Call their customer service tomorrow for the ETA.
