AVguy
#1 Posted : 12 years ago
AVguy
Need help troubleshooting please. No agitation & no spin. Lid locks, washer fills & seems to try to wash. Lid unlocks randomly. Where to start and how to remove panels to check belt etc? Thanks.
fairbank56
#2 Posted : 12 years ago
fairbank56
Groups: Expert
Cabinet is not removable. Access to motor, pulleys, belt, shifter, pump...etc. is from bottom. There should be a manual attached to the inside of the front of the cabinet. The shift actuator is a high failure item on this washer design as is the lid lock, but there have been many other problems with this design including loose connectors, broken wires, bad transmissions and faulty control boards. Another common problem has been loosening of the nut that attaches the main pulley. If it is loose, it is recommended to add loctite blue 242 threadlocker to the threads before re-tightening. Suggest you visit this site to learn more about this washer design. With the manual, you can go into service mode to check various things, check and reset any error codes and perform the calibrate function which is required after replacing certain parts.
Eric
Troubleshooting Help!! (Dishwasher Repair)
by Guest 2 years ago
Jenn Air SVD48600P Downdraft not working, need troubleshooting help (Oven Repair (including Ranges and Cooktops))
by Don Tumas 3 years ago
Troubleshooting help before I order parts (Washer Repair)
by GoogleAndroid 8 years ago
Troubleshooting Help: Heats at first, then just cold air..? (Dryer Repair)
by KatieWisc 8 years ago
troubleshooting help (Dryer Repair)
by claggett63 10 years ago
Need Troubleshooting Help (Refrigerator & Freezer Repair)
by moodymail 12 years ago
Whirlpool RBS245PDB11 Troubleshooting help (Oven Repair (including Ranges and Cooktops))
by db336 13 years ago
Ice dispenser - troubleshooting help! (Refrigerator & Freezer Repair)
by supercharge 14 years ago
Dryer Will Not Start - Need troubleshooting help (Dryer Repair)
by quickdraw841 14 years ago
by johnl 17 years ago
Troubleshooting Help Needed (Oven Repair (including Ranges and Cooktops))
by bobar 17 years ago
