AVguy
#1 Posted : Saturday, March 2, 2013 8:16:43 AM(UTC)
AVguy
Need help troubleshooting please. No agitation & no spin. Lid locks, washer fills & seems to try to wash. Lid unlocks randomly. Where to start and how to remove panels to check belt etc? Thanks.
fairbank56
#2 Posted : Saturday, March 2, 2013 8:34:24 AM(UTC)
fairbank56
Groups: Expert
Cabinet is not removable. Access to motor, pulleys, belt, shifter, pump...etc. is from bottom. There should be a manual attached to the inside of the front of the cabinet. The shift actuator is a high failure item on this washer design as is the lid lock, but there have been many other problems with this design including loose connectors, broken wires, bad transmissions and faulty control boards. Another common problem has been loosening of the nut that attaches the main pulley. If it is loose, it is recommended to add loctite blue 242 threadlocker to the threads before re-tightening. Suggest you visit this site to learn more about this washer design. With the manual, you can go into service mode to check various things, check and reset any error codes and perform the calibrate function which is required after replacing certain parts.
Eric
Troubleshooting Help!! (Dishwasher Repair)
by Guest 6/20/2023 1:14:28 PM(UTC)
Jenn Air SVD48600P Downdraft not working, need troubleshooting help (Oven Repair (including Ranges and Cooktops))
by Don Tumas 1/5/2022 5:53:18 PM(UTC)
Troubleshooting help before I order parts (Washer Repair)
by GoogleAndroid 3/16/2017 8:40:29 PM(UTC)
Troubleshooting Help: Heats at first, then just cold air..? (Dryer Repair)
by KatieWisc 2/16/2017 12:56:56 PM(UTC)
troubleshooting help (Dryer Repair)
by claggett63 11/23/2014 7:53:58 AM(UTC)
Need Troubleshooting Help (Refrigerator & Freezer Repair)
by moodymail 4/11/2013 7:39:15 PM(UTC)
Whirlpool RBS245PDB11 Troubleshooting help (Oven Repair (including Ranges and Cooktops))
by db336 2/17/2012 9:17:29 PM(UTC)
Ice dispenser - troubleshooting help! (Refrigerator & Freezer Repair)
by supercharge 9/4/2011 2:14:38 PM(UTC)
Dryer Will Not Start - Need troubleshooting help (Dryer Repair)
by quickdraw841 4/2/2011 8:26:18 AM(UTC)
by johnl 3/17/2008 12:58:15 PM(UTC)
Troubleshooting Help Needed (Oven Repair (including Ranges and Cooktops))
by bobar 11/10/2007 9:40:33 AM(UTC)
