gretchen
#1 Posted : Friday, February 1, 2008 3:54:32 AM(UTC)
gretchen
I ordered a defrost timer and cannot find where to put the part. Please help.
gretchen
#2 Posted : Friday, February 1, 2008 4:00:43 AM(UTC)
gretchen
I ordered a defrost control and cannot find where to put it on my side by side maytag part number er61005988 ADP defrost. Do you have a suggestion.
#3 Posted : Friday, February 1, 2008 12:15:44 PM(UTC)
The adaptive defrost control (#13 on the controls break down diagram) is located in the far right corner inside the housing.
Unplug the refrigerator.
To access the part you have to remove the light shield (#21 on the controls break down diagram) by releasing the tab on each side on the back of the light shield and pulling the part toward yourself.
Then you have to remove the screw on each side of the control panel (#23 on the controls break down diagram) and remove the control panel.
Then you have to remove the screw on each side of the heat shield (#19 on the controls break down diagram) and the screw (#2 on the controls break down diagram) holding the housing to the back wall and carefully pull the housing toward yourself.
Unplug the old PCB and remove it. Install the new one (do not remove the new PCB from the plastic box. It should be installed in the box.
- The part number for the adaptive defrost control is AP3160614
Here are the break down diagrams for the Maytag refrigerator Model MZD2766GEQ
Good luck.
Jump defrost timer (Refrigerator & Freezer Repair)
by baechlem 4/21/2020 12:21:48 PM(UTC)
Can't find the defrost timer (Refrigerator & Freezer Repair)
by Ardee348 3/14/2020 12:52:47 PM(UTC)
Refrigerator defrost timer (Refrigerator & Freezer Repair)
by Cabob 3/12/2019 5:38:53 AM(UTC)
Defrost Timer Setting (Refrigerator & Freezer Repair)
by Rattletrap45 11/21/2018 5:30:39 AM(UTC)
Defrost timer ready to defrost and blows circuit breaker (Refrigerator & Freezer Repair)
by DeweyBoo 6/6/2018 5:18:48 PM(UTC)
Refrigerator shuts off after replacing defrost timer (Refrigerator & Freezer Repair)
by Blaine211 9/13/2017 4:44:33 PM(UTC)
Frigidaire defrost timer (Refrigerator & Freezer Repair)
by Jefe60 9/9/2017 1:57:46 PM(UTC)
setting a defrost timer (Refrigerator & Freezer Repair)
by e4g76 6/30/2017 1:15:41 PM(UTC)
Where is the defrost timer located on Amana ARS2667AW (Refrigerator & Freezer Repair)
by f117b2 6/9/2017 4:55:09 AM(UTC)
GE Fridge running a little hot bad defrost timer/compressor? (Refrigerator & Freezer Repair)
by Maddrnkm 4/14/2017 3:27:39 PM(UTC)
by rt4x4 4/4/2017 9:01:48 AM(UTC)
New defrost timer requires tap to start (Refrigerator & Freezer Repair)
by Donro 10/5/2016 8:37:14 AM(UTC)
I don't see a defrost thermostat, nor a defrost timer. (Refrigerator & Freezer Repair)
by JoeH55 8/12/2016 10:06:09 AM(UTC)
Defrost timer stops turning (Refrigerator & Freezer Repair)
by Defroster 7/31/2016 1:24:37 PM(UTC)
Four defrost timers ALL bad? (Refrigerator & Freezer Repair)
by Defroster 12/6/2015 7:30:28 PM(UTC)
