oven doesn't work everything else does. Was told it was the oven control board. also said i would have to by the clock timer which still works, can anyone help. J
Groups: APP Team
Hi. If you not getting 240VAC to the bake and broil elements then the control board/clock assembly should be replaced Part number: 316455400
