Jleering
#1 Posted : 12 years ago
Jleering
oven doesn't work everything else does. Was told it was the oven control board. also said i would have to by the clock timer which still works, can anyone help.
J
Simon / APP Team
#2 Posted : 12 years ago
Simon / APP Team
Groups: APP Team
Hi.
If you not getting 240VAC to the bake and broil elements then the control board/clock assembly should be replaced
Part number: 316455400
You also may need the overlay Part number: 316220701
Here are the breakdown diagrams and Backguard parts for Frigidaire FEF336FMC - AppliancePartsPros.com
Post the results.
Simon.
Bosch Bottom Oven Doesn't work (Oven Repair (including Ranges and Cooktops))
by sc1984 5 years ago
Whirlpool Electric Oven Doesn't Work (Oven Repair (including Ranges and Cooktops))
by pandrada 9 years ago
Maytag MES5752BAS oven doesn't work after self clean (Oven Repair (including Ranges and Cooktops))
by myovensucks 10 years ago
Oven doesn't work at all (Oven Repair (including Ranges and Cooktops))
by AngieR 11 years ago
clock flashes 12:00 and oven doesn't work (Oven Repair (including Ranges and Cooktops))
by enossr 11 years ago
Oven doesn't work (Oven Repair (including Ranges and Cooktops))
by vonholbrook 12 years ago
Frigidaire - loud pop now oven doesn't work (Oven Repair (including Ranges and Cooktops))
by chansman 12 years ago
bake function of gas oven doesn't work (Oven Repair (including Ranges and Cooktops))
by luckobucko 12 years ago
My oven doesn't work (Oven Repair (including Ranges and Cooktops))
by David19 13 years ago
Thermador-Oven doesn't work after self clean (Oven Repair (including Ranges and Cooktops))
by Skyvu 13 years ago
Control Panel and Oven Doesn't Work (Oven Repair (including Ranges and Cooktops))
by cfun 13 years ago
Kitchen Aid dual fuel range, oven doesn't work (Oven Repair (including Ranges and Cooktops))
by bkvanbek 14 years ago
magic chef oven doesn't work (Oven Repair (including Ranges and Cooktops))
by davidhelminski 14 years ago
Oven doesn't work, but range and broiler do (Oven Repair (including Ranges and Cooktops))
by jconway1968 14 years ago
by Robin Tosky Monzingo 14 years ago
