vonholbrook
#1 Posted : Monday, April 8, 2013 11:50:12 AM(UTC)
vonholbrook
Neither the Bake or Broil elements on my Frigidaire range (GLEFS77CQB) are working. The stove top elements work just fine. There are no error codes displayed. Any help would be greatly appreciated.
#2 Posted : Tuesday, April 9, 2013 2:05:56 PM(UTC)
Parts for Frigidaire GLEFS77CQB Range - AppliancePartsPros.com
See the attachment for the wiring diagram
Since you said that there are no error codes I am assuming that the control display works.
Also that the oven light and element indicator lights work.
If the unit stays in preheat (never comes ready) then odds are that the control board/timer is shot.
I would remove the back and check the wiring from the control board to the elements just to be sure it is OK.
Be sure to unplug the unit when working on it.
File Attachment(s):
GLEFS77.pdf (417kb) downloaded 9 time(s).
Bosch Bottom Oven Doesn't work (Oven Repair (including Ranges and Cooktops))
by sc1984 3/28/2020 11:37:27 AM(UTC)
Whirlpool Electric Oven Doesn't Work (Oven Repair (including Ranges and Cooktops))
by pandrada 10/17/2016 3:58:07 AM(UTC)
Maytag MES5752BAS oven doesn't work after self clean (Oven Repair (including Ranges and Cooktops))
by myovensucks 9/9/2015 7:35:53 AM(UTC)
Oven doesn't work at all (Oven Repair (including Ranges and Cooktops))
by AngieR 3/13/2014 10:32:10 AM(UTC)
clock flashes 12:00 and oven doesn't work (Oven Repair (including Ranges and Cooktops))
by enossr 11/14/2013 6:19:35 AM(UTC)
by Jleering 1/22/2013 5:49:21 AM(UTC)
Frigidaire - loud pop now oven doesn't work (Oven Repair (including Ranges and Cooktops))
by chansman 1/11/2013 3:49:34 PM(UTC)
bake function of gas oven doesn't work (Oven Repair (including Ranges and Cooktops))
by luckobucko 12/16/2012 9:08:18 AM(UTC)
My oven doesn't work (Oven Repair (including Ranges and Cooktops))
by David19 9/24/2012 5:50:52 PM(UTC)
Thermador-Oven doesn't work after self clean (Oven Repair (including Ranges and Cooktops))
by Skyvu 3/13/2012 11:08:26 AM(UTC)
Control Panel and Oven Doesn't Work (Oven Repair (including Ranges and Cooktops))
by cfun 12/2/2011 12:59:19 PM(UTC)
Kitchen Aid dual fuel range, oven doesn't work (Oven Repair (including Ranges and Cooktops))
by bkvanbek 9/26/2011 5:16:43 PM(UTC)
magic chef oven doesn't work (Oven Repair (including Ranges and Cooktops))
by davidhelminski 6/6/2011 12:44:20 PM(UTC)
Oven doesn't work, but range and broiler do (Oven Repair (including Ranges and Cooktops))
by jconway1968 11/29/2010 7:33:54 AM(UTC)
by Robin Tosky Monzingo 11/22/2010 4:12:15 PM(UTC)
