vonholbrook
#1 Posted : 12 years ago
vonholbrook
Neither the Bake or Broil elements on my Frigidaire range (GLEFS77CQB) are working. The stove top elements work just fine. There are no error codes displayed. Any help would be greatly appreciated.
#2 Posted : 12 years ago
Parts for Frigidaire GLEFS77CQB Range - AppliancePartsPros.com
See the attachment for the wiring diagram
Since you said that there are no error codes I am assuming that the control display works.
Also that the oven light and element indicator lights work.
If the unit stays in preheat (never comes ready) then odds are that the control board/timer is shot.
I would remove the back and check the wiring from the control board to the elements just to be sure it is OK.
Be sure to unplug the unit when working on it.
File Attachment(s):
GLEFS77.pdf (417kb) downloaded 9 time(s).
Bosch Bottom Oven Doesn't work (Oven Repair (including Ranges and Cooktops))
by sc1984 5 years ago
Whirlpool Electric Oven Doesn't Work (Oven Repair (including Ranges and Cooktops))
by pandrada 8 years ago
Maytag MES5752BAS oven doesn't work after self clean (Oven Repair (including Ranges and Cooktops))
by myovensucks 10 years ago
Oven doesn't work at all (Oven Repair (including Ranges and Cooktops))
by AngieR 11 years ago
clock flashes 12:00 and oven doesn't work (Oven Repair (including Ranges and Cooktops))
by enossr 11 years ago
by Jleering 12 years ago
Frigidaire - loud pop now oven doesn't work (Oven Repair (including Ranges and Cooktops))
by chansman 12 years ago
bake function of gas oven doesn't work (Oven Repair (including Ranges and Cooktops))
by luckobucko 12 years ago
My oven doesn't work (Oven Repair (including Ranges and Cooktops))
by David19 13 years ago
Thermador-Oven doesn't work after self clean (Oven Repair (including Ranges and Cooktops))
by Skyvu 13 years ago
Control Panel and Oven Doesn't Work (Oven Repair (including Ranges and Cooktops))
by cfun 13 years ago
Kitchen Aid dual fuel range, oven doesn't work (Oven Repair (including Ranges and Cooktops))
by bkvanbek 14 years ago
magic chef oven doesn't work (Oven Repair (including Ranges and Cooktops))
by davidhelminski 14 years ago
Oven doesn't work, but range and broiler do (Oven Repair (including Ranges and Cooktops))
by jconway1968 14 years ago
by Robin Tosky Monzingo 14 years ago
