Jleering
#1 Posted : Tuesday, January 22, 2013 5:49:21 AM(UTC)
Jleering
oven doesn't work everything else does. Was told it was the oven control board. also said i would have to by the clock timer which still works, can anyone help.
J
Simon / APP Team
#2 Posted : Tuesday, January 22, 2013 12:55:23 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
If you not getting 240VAC to the bake and broil elements then the control board/clock assembly should be replaced
Part number: 316455400
You also may need the overlay Part number: 316220701
Here are the breakdown diagrams and Backguard parts for Frigidaire FEF336FMC - AppliancePartsPros.com
Post the results.
Simon.
Guest (4)
Bosch Bottom Oven Doesn't work (Oven Repair (including Ranges and Cooktops))
by sc1984 3/28/2020 11:37:27 AM(UTC)
Whirlpool Electric Oven Doesn't Work (Oven Repair (including Ranges and Cooktops))
by pandrada 10/17/2016 3:58:07 AM(UTC)
Maytag MES5752BAS oven doesn't work after self clean (Oven Repair (including Ranges and Cooktops))
by myovensucks 9/9/2015 7:35:53 AM(UTC)
Oven doesn't work at all (Oven Repair (including Ranges and Cooktops))
by AngieR 3/13/2014 10:32:10 AM(UTC)
clock flashes 12:00 and oven doesn't work (Oven Repair (including Ranges and Cooktops))
by enossr 11/14/2013 6:19:35 AM(UTC)
Oven doesn't work (Oven Repair (including Ranges and Cooktops))
by vonholbrook 4/8/2013 11:50:12 AM(UTC)
Frigidaire - loud pop now oven doesn't work (Oven Repair (including Ranges and Cooktops))
by chansman 1/11/2013 3:49:34 PM(UTC)
bake function of gas oven doesn't work (Oven Repair (including Ranges and Cooktops))
by luckobucko 12/16/2012 9:08:18 AM(UTC)
My oven doesn't work (Oven Repair (including Ranges and Cooktops))
by David19 9/24/2012 5:50:52 PM(UTC)
Thermador-Oven doesn't work after self clean (Oven Repair (including Ranges and Cooktops))
by Skyvu 3/13/2012 11:08:26 AM(UTC)
Control Panel and Oven Doesn't Work (Oven Repair (including Ranges and Cooktops))
by cfun 12/2/2011 12:59:19 PM(UTC)
Kitchen Aid dual fuel range, oven doesn't work (Oven Repair (including Ranges and Cooktops))
by bkvanbek 9/26/2011 5:16:43 PM(UTC)
magic chef oven doesn't work (Oven Repair (including Ranges and Cooktops))
by davidhelminski 6/6/2011 12:44:20 PM(UTC)
Oven doesn't work, but range and broiler do (Oven Repair (including Ranges and Cooktops))
by jconway1968 11/29/2010 7:33:54 AM(UTC)
by Robin Tosky Monzingo 11/22/2010 4:12:15 PM(UTC)
