Tested the soap dispenser actuator and it tested good. Ran a complete cycle with a volt meter hooked up to soap dispenser actuator wires and did not get any voltage. Not sure if this is a control board problem.
Any advice would be appreciated
Wayne
Groups: APP Team
Thank you. I will order it then post how it goes.
Groups: APP Team
Installed new control panel. Dishwasher now performs like new.
Groups: APP Team
Congratulations on the good job.
Simon.
Hey Simon,
I hate to bother you again but my soap door is still not opening. Worked the first time but not since. I ran the cycle again with the volt meter hooked up and it is getting 120 volts to the actuator but for only 1 minute on a stop watch. When I test the soap door hooked directly to 120 volts it takes 1 minute 22 seconds for the actuator to open the door. Is this a normal time for the actuator to work and should I be getting voltage to it for more than 1 minute?
Thanks Wayne
Groups: APP Team
Hi. Checked all possible sources with no luck.Nobody mentions for how long the wax motor is energized. You should replace the dispenser Part number: WD12X10220
and return the control board back if you got it from APP. Thank you. Simon.
