Waynebo64
#1 Posted : Thursday, January 10, 2013 8:41:56 AM(UTC)
Waynebo64
Tested the soap dispenser actuator and it tested good. Ran a complete cycle with a volt meter hooked up to soap dispenser actuator wires and did not get any voltage. Not sure if this is a control board problem.
Any advice would be appreciated
Wayne
Simon / APP Team
#2 Posted : Thursday, January 10, 2013 11:37:46 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
If you are not getting 120VAC to the dispenser - replace the control board Part number: WD21X10366
Here are the breakdown diagrams and Escutcheon & Door Assembly parts for GE GHDA690P00BB - AppliancePartsPros.com
Post the results.
Simon.
Waynebo64
#3 Posted : Thursday, January 10, 2013 1:22:59 PM(UTC)
Waynebo64
Thank you. I will order it then post how it goes.
Simon / APP Team
#4 Posted : Thursday, January 10, 2013 2:20:23 PM(UTC)
Simon / APP Team
Groups: APP Team
You are welcome.
Simon.
Waynebo64
#5 Posted : Monday, January 14, 2013 5:31:31 PM(UTC)
Waynebo64
Installed new control panel. Dishwasher now performs like new.
Simon / APP Team
#6 Posted : Monday, January 14, 2013 7:46:38 PM(UTC)
Simon / APP Team
Groups: APP Team
Congratulations on the good job.
Simon.
Waynebo64
#7 Posted : Wednesday, January 16, 2013 7:49:19 AM(UTC)
Waynebo64
Hey Simon,
I hate to bother you again but my soap door is still not opening. Worked the first time but not since. I ran the cycle again with the volt meter hooked up and it is getting 120 volts to the actuator but for only 1 minute on a stop watch. When I test the soap door hooked directly to 120 volts it takes 1 minute 22 seconds for the actuator to open the door. Is this a normal time for the actuator to work and should I be getting voltage to it for more than 1 minute?
Thanks Wayne
Simon / APP Team
#8 Posted : Wednesday, January 16, 2013 11:15:52 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Checked all possible sources with no luck.Nobody mentions for how long the wax motor is energized.
You should replace the dispenser
Part number: WD12X10220
and return the control board back if you got it from APP.
Thank you.
Simon.
