federicokiki
#1 Posted : Wednesday, January 2, 2013 5:39:39 PM(UTC)
federicokiki
Oven won't heat, stays on Lo. I replaced the igniter and no luck. It clearly glows but I dont hear any gas coming out. I found a forum on-line that had a person with the same exact problem on the same range. They replaced the microcomputer and that did not work. They mentioned a fuse/fuses, any ideas? The broiler and cooktop work fines.
Read more: http://forum.appliancepartspros...-heat.html#ixzz2GsO9iqB4
http://forum.appliancepartspros.com
#2 Posted : Thursday, January 3, 2013 3:37:27 PM(UTC)
Hello,
If there is no gas flow with the new igniter then the problem is a bad gas safety valve.
- The gas valve assembly Part number: 9755424
federicokiki
#3 Posted : Friday, February 1, 2013 6:56:13 PM(UTC)
federicokiki
Hello Gene,
I have received the gas valve assembly as described in the auction. After replacing the valve assembly, the stovetop works but the oven does not heat up. Any more ideas or suggestions?
#4 Posted : Tuesday, February 5, 2013 2:10:59 PM(UTC)
There is the oven on-off switch on the side of the pressure regulator. Make sure it is on.
frigidaire wall oven 6564063 (Oven Repair (including Ranges and Cooktops))
by Guest 7/2/2024 12:40:53 PM(UTC)
Replacing oven bake burner on GE JCB920BEC4BB (Oven Repair (including Ranges and Cooktops))
by Guest 6/30/2024 7:37:19 AM(UTC)
GE Profile Oven heating very slowly (Oven Repair (including Ranges and Cooktops))
by Reddogmatic 6/23/2024 4:53:08 PM(UTC)
Frigidaire oven won’t heat (Oven Repair (including Ranges and Cooktops))
by Jseeders 6/16/2024 10:23:51 AM(UTC)
Whirlpool Oven/Microwave combo E1 F2 (Oven Repair (including Ranges and Cooktops))
by MalcolmR 6/12/2024 10:02:00 AM(UTC)
Recommend gas range single oven (General Talk)
by 007noob 6/10/2024 3:19:57 PM(UTC)
Solved: Removing microwave unit from wall mounted Oven/Microwave combo (Oven Repair (including Ranges and Cooktops))
by MalikR 6/10/2024 3:04:18 PM(UTC)
Whirlpool Gold Accubake Oven/Microwave (Oven Repair (including Ranges and Cooktops))
by Guest 6/10/2024 10:21:28 AM(UTC)
GE Wall Oven Model PT7800SH9SS (Oven Repair (including Ranges and Cooktops))
by 68catcar 5/21/2024 6:06:03 PM(UTC)
NEITHER OVEN NOR BROIL BURNER LIGHTS (Oven Repair (including Ranges and Cooktops))
by roastbredfruit 5/21/2024 3:00:41 PM(UTC)
Kitchenaid Oven range Superba kgsc308lss0 not heating up (Oven Repair (including Ranges and Cooktops))
by rattty 5/19/2024 6:51:16 PM(UTC)
Frigidaire oven issue (Dishwasher Repair)
by Guest 5/8/2024 12:45:18 PM(UTC)
Thermador double oven from '99 troubleshoot (Oven Repair (including Ranges and Cooktops))
by mike_balt 5/6/2024 4:16:42 PM(UTC)
How to pull microwave out of mw/oven combo (Oven Repair (including Ranges and Cooktops))
by cromking 5/6/2024 1:13:05 PM(UTC)
Samsung Range Overheating Oven (Oven Repair (including Ranges and Cooktops))
by ajerwin 5/6/2024 4:34:22 AM(UTC)
