JD0034
#1 Posted : Tuesday, January 1, 2013 5:13:24 PM(UTC)
JD0034
My wife told me the washer was working fine but when it hit the spin cycle it would not spin, and she smelled a kind of burning smell. I smelled it too.
The tub was drained but wouldn't spin.
I removed the front cover and tried it again. It would fill, then drain, then try to spin but wouldn't get going. I tested the lid switch, and it was triggering the motor drive fine. The motor would try to kick in and would rotate about 1/8 of a revolution, then stop and bounce back. I spun the drum by hand a bit, then clicked open/shut the lid a few times, and it tried harder to spin, but would stop. I manually turned the assembly under the drum (piece with the counterweight) and the motor would spin it about 1.5-2 revolutions, but then would slow to a stop again. The motor burning smell persisted. The belt was fine.
Unit is about 7 years old and has had no issues until this load. GE model WJSR4160D5WW.
Ideas? Thanks in advance for your assistance.
fairbank56
#2 Posted : Tuesday, January 1, 2013 5:53:21 PM(UTC)
fairbank56
Groups: Expert
It should be relatively easy to rotate the motor pulley by hand (CW as viewed from below) which will turn the belt and rotate the large pulley and transmission. Use two hands to continuously rotate the motor pulley to see if something is binding the tub. Could be clothing between the tubs. Could also be a problem with the brake cam which releases the transmission brake.
Eric
GE Washer not spinning (Washer Repair)
by zoobteach 8/29/2015 10:12:50 AM(UTC)
by atomicsynth 6/2/2015 10:36:31 PM(UTC)
GE washer not spinning any cycle (Washer Repair)
by j409 6/2/2014 7:44:19 AM(UTC)
GE Washer not Spinning (Washer Repair)
by jkomes 12/19/2013 6:52:43 PM(UTC)
GE washer not spinning out all the water (Washer Repair)
by sbryant73 11/16/2013 2:51:08 PM(UTC)
by Tigerhawk247 11/5/2013 7:14:29 PM(UTC)
by jschust 10/6/2013 9:17:23 AM(UTC)
GE washer not spinning (Washer Repair)
by dorlando 7/13/2013 6:06:17 PM(UTC)
by jlbyrnes3 4/8/2013 10:54:18 PM(UTC)
by mau397 5/6/2012 2:38:20 PM(UTC)
GE Washer not spinning and smells strange (Washer Repair)
by greenfelt22 7/26/2011 6:26:28 AM(UTC)
GE Washer not spinning. Bad motor or transmission? (Washer Repair)
by MrJosh 6/17/2009 7:02:48 AM(UTC)
