limadoc
#1 Posted : 12 years ago
limadoc
Hi all , I sure would apericate your help,.......I have a kenmore washing machine, model 11025062500 it worked for a few weeks, then all of a sudden with no warning, nota !!! no display, doesn't run, nor does it make any sounds,..............there is power to the wall plug. thanks for any help !!!!
#2 Posted : 12 years ago
Hello,
Open the control panel and check for 120 VAC between the black and the white wires connected to the machine control board. If the reading is correct, replace the machine control board.
- The machine control board Part number: 8571359
Intermittent digital display (Oven Repair (including Ranges and Cooktops))
by T.Clifton 4 years ago
Whirlpool range no digital display or oven working (Oven Repair (including Ranges and Cooktops))
by bdbwtie 11 years ago
Digital display goes out when surface burner turned on (Oven Repair (including Ranges and Cooktops))
by robertmwagner99@yahoo.com 11 years ago
Fridge side 40-50 deg and digital display reads 33 deg? (Refrigerator & Freezer Repair)
by g20zoom 12 years ago
Digital Display (Microwave Repair)
by BigBaldAL 12 years ago
Buttons and digital display non-responsive. Commercial grade unit. (Microwave Repair)
by stjalsma 12 years ago
Need help with range digital display after replacing oven heating element (Oven Repair (including Ranges and Cooktops))
by brewbaker 12 years ago
Digital display goes on and off (Oven Repair (including Ranges and Cooktops))
by justaguy11 12 years ago
Digital Display shows fridge temp at 70 degrees. (Refrigerator & Freezer Repair)
by gigi wright 13 years ago
Replacing KitchenAid digital display (Oven Repair (including Ranges and Cooktops))
by safbiker 14 years ago
No digital display therefore no oven but stove top works. (Oven Repair (including Ranges and Cooktops))
by indymom92 14 years ago
Digital display on touchpad is blank - ovens don't work (Oven Repair (including Ranges and Cooktops))
by Mais Oui 14 years ago
Maytag Electric Range Digital Display Blank (Oven Repair (including Ranges and Cooktops))
by ted_2010 15 years ago
Digital Display doesn't work on Jenn-AIR (Oven Repair (including Ranges and Cooktops))
by jacksloth 15 years ago
lost digital display, beeps when pressing buttons (Oven Repair (including Ranges and Cooktops))
by lapulapu 15 years ago
