limadoc
#1 Posted : Thursday, December 27, 2012 3:31:03 PM(UTC)
limadoc
Hi all , I sure would apericate your help,.......I have a kenmore washing machine, model 11025062500 it worked for a few weeks, then all of a sudden with no warning, nota !!! no display, doesn't run, nor does it make any sounds,..............there is power to the wall plug. thanks for any help !!!!
#2 Posted : Friday, December 28, 2012 3:57:10 PM(UTC)
Hello,
Open the control panel and check for 120 VAC between the black and the white wires connected to the machine control board. If the reading is correct, replace the machine control board.
- The machine control board Part number: 8571359
Intermittent digital display (Oven Repair (including Ranges and Cooktops))
by T.Clifton 3/4/2021 1:58:12 PM(UTC)
Whirlpool range no digital display or oven working (Oven Repair (including Ranges and Cooktops))
by bdbwtie 4/5/2014 6:57:10 AM(UTC)
Digital display goes out when surface burner turned on (Oven Repair (including Ranges and Cooktops))
by robertmwagner99@yahoo.com 12/27/2013 6:52:30 PM(UTC)
Fridge side 40-50 deg and digital display reads 33 deg? (Refrigerator & Freezer Repair)
by g20zoom 7/30/2013 11:45:19 AM(UTC)
Digital Display (Microwave Repair)
by BigBaldAL 2/22/2013 6:43:17 AM(UTC)
Buttons and digital display non-responsive. Commercial grade unit. (Microwave Repair)
by stjalsma 2/5/2013 12:40:36 PM(UTC)
Need help with range digital display after replacing oven heating element (Oven Repair (including Ranges and Cooktops))
by brewbaker 12/27/2012 3:11:57 PM(UTC)
Digital display goes on and off (Oven Repair (including Ranges and Cooktops))
by justaguy11 10/1/2012 8:29:16 PM(UTC)
Digital Display shows fridge temp at 70 degrees. (Refrigerator & Freezer Repair)
by gigi wright 3/19/2012 1:18:21 PM(UTC)
Replacing KitchenAid digital display (Oven Repair (including Ranges and Cooktops))
by safbiker 9/9/2011 12:47:34 PM(UTC)
No digital display therefore no oven but stove top works. (Oven Repair (including Ranges and Cooktops))
by indymom92 7/7/2011 12:14:39 PM(UTC)
Digital display on touchpad is blank - ovens don't work (Oven Repair (including Ranges and Cooktops))
by Mais Oui 3/31/2011 3:40:10 PM(UTC)
Maytag Electric Range Digital Display Blank (Oven Repair (including Ranges and Cooktops))
by ted_2010 5/17/2010 9:33:51 AM(UTC)
Digital Display doesn't work on Jenn-AIR (Oven Repair (including Ranges and Cooktops))
by jacksloth 11/28/2009 2:25:00 PM(UTC)
lost digital display, beeps when pressing buttons (Oven Repair (including Ranges and Cooktops))
by lapulapu 9/30/2009 7:41:15 PM(UTC)
