ovenman
#1 Posted : Thursday, December 13, 2012 7:38:00 AM(UTC)
ovenman
Have oven that went to self clean and had to unplug to release (let it cool). Oven / broiler not working. Control board or temp sensor or something else?
#2 Posted : Friday, December 14, 2012 10:12:23 AM(UTC)
Parts for Maytag MER5755QAW Range - AppliancePartsPros.com
See the attachment for the tech sheet
Not quite sure I understand.
If the unit went into self clean all by itself you will need a control (item 7 in section 03).
By the sound of it the hi-limit switch may have blown.
I think it is item 18 in section 01. If you click on it's picture a new page will open with a view of the back. Looks like it can be reset by pushing the read button back in.
It would also be a good idea to check the oven sensor.
Below is a link, check out 7, 8, 20 and 21.
http://www.applianceaid.com/electric-range-repair-topics.php
File Attachment(s):
MER5755.pdf (310kb) downloaded 1 time(s).
Confused!!! Trying to wire up a replacement motor for Kenmore 110.86983800 (Dryer Repair)
by Guest 1/17/2024 10:02:08 AM(UTC)
Confused about replacing oven igniter Frigidaire (Oven Repair (including Ranges and Cooktops))
by artemis 12/4/2017 9:24:14 AM(UTC)
F 28 code - confused by dignostics (Dryer Repair)
by dpollock 3/22/2017 11:35:46 AM(UTC)
GE fridge is confused! (Refrigerator & Freezer Repair)
by gcrashm 3/1/2017 5:28:13 PM(UTC)
confused (Refrigerator & Freezer Repair)
by jenlyn 3/3/2014 4:00:51 PM(UTC)
I'm so confused about the model # (Refrigerator & Freezer Repair)
by g9672001 8/17/2013 4:19:17 PM(UTC)
Confused on Washer Timer (Washer Repair)
by lfreng 10/24/2012 4:30:17 PM(UTC)
Confused GE Profile Washer!! HELP (Washer Repair)
by luta46 9/24/2012 5:50:27 PM(UTC)
Confused, is cardboard under refrigerator packing? (Refrigerator & Freezer Repair)
by vrineer 1/29/2012 9:39:26 AM(UTC)
Frigidaire Laundry Center confused (Washer Repair)
by rodrigo_umana 10/26/2010 6:54:12 PM(UTC)
confused and frustrated (Dishwasher Repair)
by Florenrose 5/8/2010 3:19:00 PM(UTC)
by jefferybeecher73@gmail.co 2/18/2010 6:47:04 PM(UTC)
Still confused Re: "Glide" (Dryer Repair)
by 5december 10/7/2008 9:09:42 PM(UTC)
Confused (Oven Repair (including Ranges and Cooktops))
by Mike Clifford 9/29/2008 10:10:13 AM(UTC)
Oven is confused about set temperature (Oven Repair (including Ranges and Cooktops))
by jhuff 8/28/2008 12:43:01 PM(UTC)
