Fishin' Machine
#1 Posted : Thursday, November 15, 2012 11:33:11 AM(UTC)
Fishin' Machine
I just replaced the starter relay on my Whirlpool Refrigerator model # ED5NTGXLT00. I have the temperature control for the freezer set halfway between C and Colder and the freezer temperature is around -3 degrees. I first set the refrigerator temperature to the "mid" setting which is 3 and now I have it set between 4 and coldest and the inside temperature will not go below 42 degrees. I put my hand on the compressor and it was so hot to the touch I couldn,t keep my hand on it for over about 3 seconds and I have pretty rough hands from fishing. Any suggestions?
Simon / APP Team
#2 Posted : Thursday, November 15, 2012 11:54:34 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Check if the condenser fan motor is running normal and if the condenser coils are clean.Did you put the rear cover back after you replaced the starter relay?
You may have the problem with the air flow from the freezer to the fresh food.
Adjust the air flow from the freezer to max and see if that make any difference.
Simon.
Danby Millenial Apartment sized fridge - hot compressor not cooling (Refrigerator & Freezer Repair)
by Seefost 2/7/2021 5:10:43 AM(UTC)
Hot compressor but cooling (Refrigerator & Freezer Repair)
by johehojr 6/20/2016 6:48:02 AM(UTC)
Hot Compressor After Cleaning Coils (Refrigerator & Freezer Repair)
by cmorse 5/31/2015 9:50:59 AM(UTC)
GE inverter, inverter wires, and hot compressor (Refrigerator & Freezer Repair)
by rcatty 8/16/2012 10:13:51 AM(UTC)
ge profile hot compressor (Refrigerator & Freezer Repair)
by maryb11 5/7/2012 10:59:58 AM(UTC)
warm outside walls/hot compressor (Refrigerator & Freezer Repair)
by jsmi 6/9/2011 8:49:39 AM(UTC)
Fridge slowly died, wont cool, hot compressor (Refrigerator & Freezer Repair)
by 321break 9/14/2010 8:33:05 PM(UTC)
clank from refrigerator, hot compressor (Refrigerator & Freezer Repair)
by gknigge 8/2/2010 10:09:56 AM(UTC)
Intermittent operation with hot compressor (Refrigerator & Freezer Repair)
by RMartin 9/24/2009 4:20:30 PM(UTC)
by looking4answers 6/24/2008 6:38:44 PM(UTC)
