DonQuixote
#1 Posted : Monday, November 12, 2012 9:45:19 PM(UTC)
DonQuixote
Hello,I tried to find my post from this morning but somehow it did'nt make it....Operator error I'm sure.We bought this fridge brand new when I was employed at Lowes in Tennessee,when we moved home to Colorado it began getting a buildup of ice in the rear of the unit which gets big enough to rub on the circulation fan..(?) It is quite noisey and the only way I have found to (temporaraly) fix it is to unplug overnight.For the cost of the unit I surely should not have to do this! I have tried different settings ie.warmer setting,energy saver etc.Have I purchased the most expensive piece of poop or is there a fix for this?...
Thanks, Roy Adams
ApplianceJunk
#2 Posted : Tuesday, November 13, 2012 7:36:39 AM(UTC)
ApplianceJunk
If the ice that builds up and hits the fan also builds up over the rest of the freezer coil then you have a defrost problem. If the ice build up is just near the fan then you have other sealed system problems.
Ice Buildup Under Freezer Platform, Leaks into Fridge (Refrigerator & Freezer Repair)
by MochaFiend 4/2/2024 3:21:56 PM(UTC)
Frigidaire FGHS2631PF4A Ice Buildup in Freezer (Refrigerator & Freezer Repair)
by Visualist 12/28/2021 9:16:05 AM(UTC)
GE MONOGRAM ZIC360NMRH Ice Buildup (Refrigerator & Freezer Repair)
by Dawnv 10/11/2021 7:01:04 AM(UTC)
Samsung RS261MDRS ice buildup (Refrigerator & Freezer Repair)
by AndyPanda 2/23/2020 6:24:11 PM(UTC)
Whirlpool WRT311FZDW00: Ice buildup in freezer, warm fridge (Refrigerator & Freezer Repair)
by bkbk 9/16/2019 3:42:31 PM(UTC)
KitchenAid Side-by-Side Freezer Ice buildup and cold Fridge (Refrigerator & Freezer Repair)
by Kinny82 10/15/2017 9:36:39 PM(UTC)
Old Amana Bottom Freezer with Ice Buildup (Refrigerator & Freezer Repair)
by egizzi 2/17/2017 6:39:34 AM(UTC)
Ice buildup behind fridge. (Refrigerator & Freezer Repair)
by Chadmc23 11/29/2016 3:44:06 PM(UTC)
GE Frost/Ice Buildup on Ice Chute (Refrigerator & Freezer Repair)
by timabe 4/16/2016 5:47:26 AM(UTC)
Amana Side by Side Ice Buildup and Leaking (Refrigerator & Freezer Repair)
by LavaPit 8/25/2014 10:13:44 AM(UTC)
ice buildup on the pack panel inside fridge (Refrigerator & Freezer Repair)
by bluefitness 8/3/2014 6:21:29 PM(UTC)
Ice buildup on one side of evaporator coils (Refrigerator & Freezer Repair)
by Lott 6/18/2014 6:39:59 PM(UTC)
Ice buildup on Defrost Thermostat (Refrigerator & Freezer Repair)
by russell@txwrights.com 1/20/2014 5:49:09 PM(UTC)
freezer ice buildup on bottom of floor (Refrigerator & Freezer Repair)
by donzell 7/26/2012 1:45:47 PM(UTC)
Amana SXD22S2W Not cooling enough. Ice buildup on evaporator at defrost thermostat (Refrigerator & Freezer Repair)
by DawgFan 7/7/2012 10:21:14 AM(UTC)
