DawgFan
#1 Posted : 13 years ago
DawgFan
I have an Amana side by side refridgerator. It is no longer cooling properly. I took off the back panel and noticed ice build up at the top of the evaporator, primarily at the defrost sensor. I let the ice thaw out and plugged it back in. The ice reformed within an hour of being plugged in. Any help would be appreciated.
#2 Posted : 13 years ago
Check the compressor in the back, is it warm and vibrating and the condensing coils room temperarure?
russell@txwrights.com
#3 Posted : 11 years ago
Wondering if a solution was ever found, as it seems the same as the Whirlpool issue I'm having.
Marat
#4 Posted : 11 years ago
Marat
Big job, usually evaporator coils r leaking. That's how to replace them.
https://m.youtube.com/watch?v=e5R_lf7Tnmw
