2 Pages12>
the5tjrs
#1 Posted : Friday, November 2, 2012 9:01:04 AM(UTC)
the5tjrs
Washer runs fine until it gets to the "Drain/Spin" point on the timer. It will drain, but not spin. I you manually move dial ahead, it will spin and finish the cycle. It does this on all three loan types; dark colors, casuals, etc. Bad timer, valve, control board? Thanks for your help.
Simon / APP Team
#2 Posted : Friday, November 2, 2012 9:32:43 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Based on the info you provided it's a bad timer Part number: WH12X10478
Here are the breakdown diagrams and Controls & Backsplash parts for GE GHWP1000M0WW - AppliancePartsPros.com
Post the results.
Simon.
the5tjrs
#3 Posted : Monday, November 12, 2012 6:09:49 AM(UTC)
the5tjrs
I purchased and installed the timer, however it did not solve the problem. When the washer gets to the Drain/Spin cycle, it drains the water but does not proceed into the final spin dry cycle.
fairbank56
#4 Posted : Monday, November 12, 2012 6:50:45 AM(UTC)
fairbank56
Groups: Expert
So, your saying that after agitate, it drains and the timer no longer advances on it's own? It will just sit there and run the drain pump without the timer advancing any further until you advance it manually?
Eric
the5tjrs
#5 Posted : Monday, November 12, 2012 6:57:04 AM(UTC)
the5tjrs
That is correct. It pumps the water out, then it seems to just keep on pumping even though there is no water to pump. I think it is shutting down due to the pump getting hot. If I push the timer knob in (shutting it off) then move the timer ahead just slightly and pulling the know out, it will start spinning and complete the cycle. It does this with all load types; whites, casual, delicate, etc.
fairbank56
#6 Posted : Monday, November 12, 2012 7:18:26 AM(UTC)
fairbank56
Groups: Expert
Can't find much tech info on this machine. There is no electronic control board in this unit behind the control panel, correct? There should be a tech sheet behind the control panel. Can you copy it or take a clear picture of it and post it?
Eric
the5tjrs
#7 Posted : Monday, November 12, 2012 8:52:17 AM(UTC)
the5tjrs
That is correct, there is no electronic control board. Here is a copy of the only information I found behind the control panel.
fairbank56
#8 Posted : Monday, November 12, 2012 10:28:02 AM(UTC)
fairbank56
Groups: Expert
I don't see a copy or link to it. Anyway, it seems that the timer motor is losing power when it goes from agitate to drain. In the typical non-electronic GE washer, power to the timer motor is through the water level switch which starts agitation and timer rotation. During drain and spin, timer motor power is through the water level bypass contacts in the timer. The problem your having is pointing to a timer problem but you have already replaced it. Need to see the wiring diagram for your washer but can't find it.
I have since found out that this washer has an "energy saving rinse" as do most of GE's newer models. This works by NOT spinning after the first drain. It pumps the water out after agitate but just leaves the clothes wet and doesn't spin. Then it fills with about 11 gallons of water regardless of the load size setting, agitates a little, drains and then spins. So only one final spin after the rinse cycle.
You did say the timer doesn't advance on it's own so you still have a problem if that is the case.
Eric
the5tjrs
#9 Posted : Monday, November 12, 2012 11:14:16 AM(UTC)
the5tjrs
Not sure why the photo didn't attach. I'll try again.
the5tjrs attached the following image(s):
fairbank56
#10 Posted : Monday, November 12, 2012 11:33:15 AM(UTC)
fairbank56
Groups: Expert
Too blurry, can't read timer chart or schematic. Need clear close-up of each.
Eric
GE washer won't spin, smells like burning rubber (Washer Repair)
by TimBlock 12/27/2015 12:35:03 PM(UTC)
GE washer won't spin or agitate. (Washer Repair)
by Eric9999 12/21/2015 10:19:03 AM(UTC)
GE washer won't spin during final rinse (Washer Repair)
by Asu19 10/28/2015 2:38:21 PM(UTC)
GE Washer won't spin or agitate (Washer Repair)
by whovian2015 9/30/2015 2:56:35 PM(UTC)
GE washer won't spin (Washer Repair)
by Dana021 4/28/2014 5:05:18 PM(UTC)
GE Washer Won't Spin - Lid Lock Error? (Washer Repair)
by lum 1/30/2014 11:41:30 PM(UTC)
GE Washer won't spin dry clothes (Washer Repair)
by jglascoe1691 12/10/2013 4:41:11 AM(UTC)
GE washer won't spin/agitate (Washer Repair)
by Mlsmith 10/8/2013 5:30:10 PM(UTC)
GE washer won't spin or agitate (Washer Repair)
by unclejohnforever 2/27/2013 6:58:56 AM(UTC)
GE washer won't spin - Mark (Washer Repair)
by masavrin@netzero.net 1/2/2013 9:45:50 AM(UTC)
GE Washer won't spin with heavy loads (Washer Repair)
by paulgj 10/18/2012 8:00:50 PM(UTC)
ge washer won't spin (Dishwasher Repair)
by magsw 5/24/2012 3:12:19 PM(UTC)
ge washer won't spin or wash, no blinking lights on motor (Washer Repair)
by fr45 2/28/2012 9:22:19 AM(UTC)
GE Washer won't spin but agitates (Washer Repair)
by guptamgs@hotmail.com 1/5/2012 11:29:15 AM(UTC)
GE washer won't spin unless i give it a hand. (Washer Repair)
by nannerz11 12/15/2011 1:01:23 PM(UTC)
2 Pages12>
