pogibugoy
#1 Posted : 12 years ago
pogibugoy
KitchenAid refrigerator stopped making ice, water dispenser is fine. replaced inlet water valve, still same problem. any idea what might be wrong?
#2 Posted : 12 years ago
Open the freezer door. Make sure the "on-off" switch on the right side is On. Close the flapper door on the left side to clean the optic beam and observe the LED on the right side. Post the result.
Here are the breakdown diagrams and Parts for Whirlpool KSRS25RVMS02 Refrigerator - AppliancePartsPros.com
pogibugoy
#3 Posted : 12 years ago
pogibugoy
Did everything per your suggestion, nothing happened. Is the red flashing light suppose to turn green?
#4 Posted : 12 years ago
No, but it can be steady on, blinking or completely off. I need to know its status.
pogibugoy
#5 Posted : 12 years ago
pogibugoy
light was completely off, no blinking or steady
#6 Posted : 12 years ago
I hope you did not touch the door light switch?
If that's correct, then replace the optic boards on both sides.
- The PC boards kit Part number: 4389102
pogibugoy
#7 Posted : 12 years ago
pogibugoy
light is still off but for some unknown reason, it started making ice again. Thanks anyway Gene for your pront response.
