pogibugoy
#1 Posted : Monday, October 29, 2012 7:43:43 PM(UTC)
pogibugoy
KitchenAid refrigerator stopped making ice, water dispenser is fine. replaced inlet water valve, still same problem. any idea what might be wrong?
#2 Posted : Tuesday, October 30, 2012 12:41:14 PM(UTC)
Open the freezer door. Make sure the "on-off" switch on the right side is On. Close the flapper door on the left side to clean the optic beam and observe the LED on the right side. Post the result.
Here are the breakdown diagrams and Parts for Whirlpool KSRS25RVMS02 Refrigerator - AppliancePartsPros.com
pogibugoy
#3 Posted : Tuesday, October 30, 2012 6:26:09 PM(UTC)
pogibugoy
Did everything per your suggestion, nothing happened. Is the red flashing light suppose to turn green?
#4 Posted : Wednesday, October 31, 2012 1:12:21 PM(UTC)
No, but it can be steady on, blinking or completely off. I need to know its status.
pogibugoy
#5 Posted : Wednesday, October 31, 2012 1:19:52 PM(UTC)
pogibugoy
light was completely off, no blinking or steady
#6 Posted : Wednesday, October 31, 2012 5:03:02 PM(UTC)
I hope you did not touch the door light switch?
If that's correct, then replace the optic boards on both sides.
- The PC boards kit Part number: 4389102
pogibugoy
#7 Posted : Thursday, November 1, 2012 12:28:36 PM(UTC)
pogibugoy
light is still off but for some unknown reason, it started making ice again. Thanks anyway Gene for your pront response.
