gschvach
#1 Posted : Saturday, October 13, 2012 12:18:56 PM(UTC)
gschvach
Right front element stays hot. I have to turn breaker off to shut down. Other 3 elements will not get hot.
#2 Posted : Saturday, October 13, 2012 4:57:52 PM(UTC)
gschvach
#3 Posted : Monday, October 15, 2012 7:38:54 AM(UTC)
gschvach
All frigidaire wants to do is send out a gasket kit for the knobs. How do I fix the problem of right front element heating up when not turned on? The three other elements won't turn on.
#4 Posted : Monday, October 15, 2012 11:28:09 PM(UTC)
Parts for Frigidaire GLES389FSB Range - AppliancePartsPros.com
See the attachment for the wiring diagram.
I am assuming that the oven works OK.
Unplug the unit and check the wiring to the element controls and from them to the terminal strip.
If all OK I would disconnect the right front element and see if the other elements now work.
If that does nothing disconnect the control/board for that element.
Be very careful that the unit is unplugged when working on it and that nothingcan short out when you are testing it.
This is a fairly complicated unit and may be best left to a pro.
A manual is available for purchase at the following site but is for stand alone units not a slide in unit. The sections on the element controls is the same though.
http://appliancejunk.com/forums/index.php
File Attachment(s):
GLES389.pdf (254kb) downloaded 3 time(s).
