22 Pages«<1718192021>»
gtiphil
#181 Posted : Friday, October 12, 2012 8:43:09 PM(UTC)
gtiphil
Ok. I'll order a mainboard and we'll see how it goes. Thank you very much for the help.
amathrawala
#182 Posted : Saturday, December 8, 2012 2:45:36 PM(UTC)
amathrawala
Hi Lisa,
I have the same issue. did you ever get an answer to your question ? I would be very interested. It looks like my evaporator fan is making the humming noise.
#183 Posted : Monday, December 10, 2012 7:42:14 PM(UTC)
Originally Posted by: amathrawala Go to Quoted Post
...It looks like my evaporator fan is making the humming noise...
What is the complete model number of the refrigerator?
freddyrick
#184 Posted : Sunday, January 27, 2013 5:58:04 PM(UTC)
freddyrick
Hello Gene, I have a GE gsh25sgpass. Evaporator fan motor works intermittently, currently not running. Voltages measure as follows: RW 13.6, YW 13.6, BlueW 4.6 volts DC. Is this a multispeed motor, and what does BlueW run, and is 4.6 OK?
#185 Posted : Monday, January 28, 2013 7:37:50 PM(UTC)
Hello,
The following article on our forum will explain in detail how this fan motor works and what to do to fix it - http://forum.appliancepartspros...motors-motherboards.html
There are two different kind of motors used by GE. You have to determine by yourself which one is used for your fridge before you will order it.
- The evaporator fan motor with a thermistor wired into the connecting harness Part number: WR60X10074
- The evaporator fan motor without the thermistor Part number: WR60X10185
- The main control board Part number: WR55X10942
freddyrick
#186 Posted : Wednesday, January 30, 2013 6:52:16 AM(UTC)
freddyrick
Hello,
I'll try the resistance test, but Richappy says that test doesn't help. Is the low voltage of 4.6vdc at the Blu White plug an issue, is there another way to test the motherboard?
#187 Posted : Wednesday, January 30, 2013 3:47:00 PM(UTC)
I understand your point. It's expensive repair but there are no any other choices. In order to fix the problem you have to replace both parts. It is pretty standard procedure in such situation. Unless GE will take of it. Try to call them.
freddyrick
#188 Posted : Wednesday, January 30, 2013 6:00:20 PM(UTC)
freddyrick
Now I am totally confused. Are there any specs on the voltage outputs at the plug-in to verify the motherboard? I've always tried not to throw expesive parts at a problem without verifying a fault. Although, when I cut out the motor I will test the resistance and report back to you for future reference. the motor was $30 or so. Thanks.
#189 Posted : Wednesday, January 30, 2013 8:56:40 PM(UTC)
You can find the voltage specs on the first page of this thread in the article written by Richappy..
The blue wire is the motor RPM feedback input - no sense for voltage test.
freddyrick
#190 Posted : Thursday, January 31, 2013 5:36:31 AM(UTC)
freddyrick
OK, thanks, I read that, and I have over 13vdc at both red and yellow, so for now I am going to assume the motherboard is OK. My concern was that maybe the Blu/white needed 13vdc as well. I appreciate your help with this problem, thank you.
Guest (13)
