Right front element stays hot. I have to turn breaker off to shut down. Other 3 elements will not get hot.
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) All frigidaire wants to do is send out a gasket kit for the knobs. How do I fix the problem of right front element heating up when not turned on? The three other elements won't turn on.
Here are your parts Parts for Frigidaire GLES389FSB Range - AppliancePartsPros.comSee the attachment for the wiring diagram. I am assuming that the oven works OK. Unplug the unit and check the wiring to the element controls and from them to the terminal strip. If all OK I would disconnect the right front element and see if the other elements now work. If that does nothing disconnect the control/board for that element. Be very careful that the unit is unplugged when working on it and that nothingcan short out when you are testing it. This is a fairly complicated unit and may be best left to a pro. A manual is available for purchase at the following site but is for stand alone units not a slide in unit. The sections on the element controls is the same though. http://appliancejunk.com/forums/index.php |
