3 Pages123>
Monster Rain
#1 Posted : 12 years ago
Monster Rain
Hey, guys. My Roper, Model RES7648EQ2 just stopped heating up. Should I just assume that it's the heating element, and can you point me in the direction of a good troubleshooting/walkthrough?
Thanks so much in advance.
Monster Rain
#2 Posted : 12 years ago
Monster Rain
Well, I tested the thermal fuse, which was fine, and my element had read 9 on the losest setting of resistance. My high-level thermostat is fine, too. I guess I'll check the cycling thermostat, but I don't like the way this is going...
Monster Rain
#3 Posted : 12 years ago
Monster Rain
Cycling thermostat is fine. Anyone have any ideas?
Simon / APP Team
#4 Posted : 12 years ago
Simon / APP Team
Groups: APP Team
Have you checked if there is 240VAC to the dryer?
Simon.
Monster Rain
#5 Posted : 12 years ago
Monster Rain
No, but I'm not sure how. I'll google it. Thanks a lot!
Simon / APP Team
#6 Posted : 12 years ago
Simon / APP Team
Groups: APP Team
You are welcome.
Simon.
Monster Rain
#7 Posted : 12 years ago
Monster Rain
Yes, it's 240VAC. It's not making any damn sense...I noticed, though, that it shuts off when you turn it to the end part of the auto-dry cycle.
Monster Rain
#8 Posted : 12 years ago
Monster Rain
Sorry, I meant that it is getting the proper voltage, like 249.
And it shuts off at the wrinkle prevent of the auto-sense dry cycle. This is infuriating.
Simon / APP Team
#9 Posted : 12 years ago
Simon / APP Team
Groups: APP Team
Hi.
Here what you need to do:
- with dryer turned to heat check if there is 240VAC across the heating element (if yes - replace it)
- with unit unplugged check continuity of the thermal cutoff, operating thermostat, hi-limit thermostat (replace if needed).
-with unit unplugged open the control panel, set the timer to Timed-regular and check continuity TM-OR,BK-R,T-W.
- If everything checks out OK then most likely the motor switch contacts 1M-2M not closing.
Here are the breakdown diagrams and Bulkhead parts for Roper RES7648EQ2 - AppliancePartsPros.com
Post the results.
Simon.
Monster Rain
#10 Posted : 12 years ago
Monster Rain
Thanks again, will post asap.
Roper Element replacement (Dryer Repair)
by Monster Rain 12 years ago
3 Pages123>
