3 Pages123>
Monster Rain
#1 Posted : Thursday, October 11, 2012 3:38:59 AM(UTC)
Monster Rain
Hey, guys. My Roper, Model RES7648EQ2 just stopped heating up. Should I just assume that it's the heating element, and can you point me in the direction of a good troubleshooting/walkthrough?
Thanks so much in advance.
Monster Rain
#2 Posted : Thursday, October 11, 2012 6:51:04 AM(UTC)
Monster Rain
Well, I tested the thermal fuse, which was fine, and my element had read 9 on the losest setting of resistance. My high-level thermostat is fine, too. I guess I'll check the cycling thermostat, but I don't like the way this is going...
Monster Rain
#3 Posted : Thursday, October 11, 2012 7:34:14 AM(UTC)
Monster Rain
Cycling thermostat is fine. Anyone have any ideas?
Simon / APP Team
#4 Posted : Thursday, October 11, 2012 11:34:18 AM(UTC)
Simon / APP Team
Groups: APP Team
Have you checked if there is 240VAC to the dryer?
Simon.
Monster Rain
#5 Posted : Friday, October 12, 2012 8:51:46 AM(UTC)
Monster Rain
No, but I'm not sure how. I'll google it. Thanks a lot!
Simon / APP Team
#6 Posted : Friday, October 12, 2012 10:27:25 AM(UTC)
Simon / APP Team
Groups: APP Team
You are welcome.
Simon.
Monster Rain
#7 Posted : Sunday, October 21, 2012 2:23:35 PM(UTC)
Monster Rain
Yes, it's 240VAC. It's not making any damn sense...I noticed, though, that it shuts off when you turn it to the end part of the auto-dry cycle.
Monster Rain
#8 Posted : Monday, October 22, 2012 5:58:32 AM(UTC)
Monster Rain
Sorry, I meant that it is getting the proper voltage, like 249.
And it shuts off at the wrinkle prevent of the auto-sense dry cycle. This is infuriating.
Simon / APP Team
#9 Posted : Monday, October 22, 2012 8:33:19 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Here what you need to do:
- with dryer turned to heat check if there is 240VAC across the heating element (if yes - replace it)
- with unit unplugged check continuity of the thermal cutoff, operating thermostat, hi-limit thermostat (replace if needed).
-with unit unplugged open the control panel, set the timer to Timed-regular and check continuity TM-OR,BK-R,T-W.
- If everything checks out OK then most likely the motor switch contacts 1M-2M not closing.
Here are the breakdown diagrams and Bulkhead parts for Roper RES7648EQ2 - AppliancePartsPros.com
Post the results.
Simon.
Monster Rain
#10 Posted : Monday, October 22, 2012 8:47:22 AM(UTC)
Monster Rain
Thanks again, will post asap.
Roper Element replacement (Dryer Repair)
by Monster Rain 10/11/2012 3:39:01 AM(UTC)
3 Pages123>
