Jlski
#1 Posted : Tuesday, October 9, 2012 12:18:25 PM(UTC)
Jlski
need steps to follow to replace blower wheel. top, front, and drum removed. what next?
Simon / APP Team
#2 Posted : Tuesday, October 9, 2012 1:11:42 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Remove the screw and clamp holding the blower and pull out the blower.
Memories the way the clamp is installed.
Here are the breakdown diagrams and Backsplash, Blower & Motor Assembly parts for GE DWSR405GB1WW - AppliancePartsPros.com
Simon.
Jlski
#3 Posted : Wednesday, October 10, 2012 7:55:38 AM(UTC)
Jlski
Originally Posted by: Simon / APP Team Go to Quoted Post
Hi.
Simon.
actually for this model you need to remove the two screws that hold the motor mount bracket to the base and the two long screws on the front that hold the motor attached blower flange to the blower assembly. Then you can slightly lift and pull the motor assembly with blower wheel attached towards the inside of the dryer. expect a lot of dust which in my case caused pushed the wheel into contact with the front assembly housing and caused the screeching noise.
Guest (5)
