I have replaced the cycling thermostat. Both the old one and he new one show continuity across the outer leads and 6.8-7.2 (200K) on the inner leads. Dryer occasionally heats but usually does not. HELP What next. I have checked the fuse and the other thermostats.:confused:
Groups: APP Team
Hi. Replace the control coils, most likely that what's wrong Part number: 279834
Post the results. Simon.
Originally Posted by: Simon / APP Team  Hi. Replace the control coils, most likely that what's wrong Part number: 279834
Post the results. Simon. I think you are right......
