need steps to follow to replace blower wheel. top, front, and drum removed. what next?
Groups: APP Team
Originally Posted by: Simon / APP Team  actually for this model you need to remove the two screws that hold the motor mount bracket to the base and the two long screws on the front that hold the motor attached blower flange to the blower assembly. Then you can slightly lift and pull the motor assembly with blower wheel attached towards the inside of the dryer. expect a lot of dust which in my case caused pushed the wheel into contact with the front assembly housing and caused the screeching noise.
