I replaced the electronic control panel (a Whirlpool part) and the dishwasher still malfunctions. The lights flash and it doesn't operate. Suggestions?
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman den man, you posted an initial reply to my question about checking the resistance in the bimetal fuselink. Now I cannot find that response. Where did it go?
Can you please repeat that first recommendation that you made? I believe I recall that you said to check the resistance across the the Thermal Fuse, Item Number AP4423189 / Manufacturer's Number W10258275 by Whirlpool. I believe you said it should be 0 ohms. Is that correct? Any special tips in doing this?
Since you have lights the fuse will be OK. It is Item 6 in Section 1 of the parts if you look at the wiring diagram it kills all power to the control board. |
D-u-h-h-h, on my part. Thanks for calling that to my attention. Also, I just now saw where you had attached the tech sheet. I just printed it out. As soon as I find my magnifying glass for these old eyes, I'll start the process. Thanks again, I'll keep you posted. Wish me luck.
