Ron in Atlanta burbs
#1 Posted : Sunday, September 30, 2012 11:56:17 AM(UTC)
I replaced the electronic control panel (a Whirlpool part) and the dishwasher still malfunctions. The lights flash and it doesn't operate. Suggestions?
#2 Posted : Tuesday, October 2, 2012 12:25:15 AM(UTC)
Replacement parts for Whirlpool KUDI02FRSS1 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com
Try the diagnostics.
Could be a keypad problem. You would have to check the keypad output with a meter to confirm this.
File Attachment(s):
KUDI02F.pdf (245kb) downloaded 13 time(s).
#3 Posted : Tuesday, October 2, 2012 8:50:13 AM(UTC)
Originally Posted by: denman Go to Quoted Post
den man,
you posted an initial reply to my question about checking the resistance in the bimetal fuselink. Now I cannot find that response. Where did it go?
#4 Posted : Tuesday, October 2, 2012 1:38:14 PM(UTC)
Sorry but I do not know.
#5 Posted : Wednesday, October 3, 2012 3:24:39 AM(UTC)
Can you please repeat that first recommendation that you made? I believe I recall that you said to check the resistance across the the Thermal Fuse, Item Number AP4423189 / Manufacturer's Number W10258275 by Whirlpool. I believe you said it should be 0 ohms. Is that correct? Any special tips in doing this?
#6 Posted : Wednesday, October 3, 2012 4:36:45 AM(UTC)
Since you have lights the fuse will be OK.
It is Item 6 in Section 1 of the parts if you look at the wiring diagram it kills all power to the control board.
#7 Posted : Thursday, October 4, 2012 6:48:58 AM(UTC)
D-u-h-h-h, on my part. Thanks for calling that to my attention. Also, I just now saw where you had attached the tech sheet. I just printed it out. As soon as I find my magnifying glass for these old eyes, I'll start the process. Thanks again, I'll keep you posted. Wish me luck.
No Water Fill…KitchenAid Dishwasher KUDS03FSSS3 (Dishwasher Repair)
by irvingtelder 11/22/2023 7:02:56 AM(UTC)
Kitchenaid dishwasher pump? (Dishwasher Repair)
by Guest 6/11/2023 10:15:41 AM(UTC)
KUDS02FRSS2 Kitchenaid dishwasher (Dishwasher Repair)
by RepairDude61 7/2/2022 3:45:51 PM(UTC)
KitchenAid Dishwasher Not drying (Dishwasher Repair)
by louie@DFW 4/8/2022 5:15:51 PM(UTC)
Kitchenaid Dishwasher Multiple Errors (Dishwasher Repair)
by flamingvan@yahoo.com 12/6/2021 3:49:43 AM(UTC)
Kitchenaid Dishwasher F9E4 (Dishwasher Repair)
by louisd 10/17/2021 4:22:16 PM(UTC)
Kitchenaid Dishwasher diverter motor replacement (Dishwasher Repair)
by kitchdish 5/28/2021 12:32:35 PM(UTC)
KitchenAid Dishwasher Issue (Dishwasher Repair)
by facecard 3/19/2021 6:20:02 AM(UTC)
KitchenAid Dishwasher KUDS30IXBL Thermal Fuse (Dishwasher Repair)
by Ed Explains It 3/16/2021 10:34:44 AM(UTC)
KitchenAid Dishwasher will not complete cleaning Cycle (Dishwasher Repair)
by KyKatt 12/16/2020 12:23:50 PM(UTC)
KitchenAid Dishwasher no water (Dishwasher Repair)
by tjlester 9/25/2020 10:51:39 AM(UTC)
KitchenAid dishwasher filling up when turned off (Dishwasher Repair)
by RinOakland 9/14/2020 8:50:00 AM(UTC)
KitchenAid Dishwasher pops open(latch changed) (Dishwasher Repair)
by saads 8/8/2020 9:51:27 PM(UTC)
Kitchenaid Dishwasher Not Starting (Dishwasher Repair)
by willmt10 6/28/2020 4:22:06 PM(UTC)
(Help) KitchenAid Dishwasher wont fully drain on normal cycle (Dishwasher Repair)
by ToNeG24 5/28/2020 9:16:06 PM(UTC)
