Ron in Atlanta burbs
#1 Posted : Sunday, September 30, 2012 2:56:17 PM(UTC)
I replaced the electronic control panel (a Whirlpool part) and the dishwasher still malfunctions. The lights flash and it doesn't operate. Suggestions?
#2 Posted : Tuesday, October 2, 2012 3:25:15 AM(UTC)
Replacement parts for Whirlpool KUDI02FRSS1 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com
Try the diagnostics.
Could be a keypad problem. You would have to check the keypad output with a meter to confirm this.
File Attachment(s):
KUDI02F.pdf (245kb) downloaded 13 time(s).
You cannot view/download attachments. Try to login or register.
#3 Posted : Tuesday, October 2, 2012 11:50:13 AM(UTC)
Originally Posted by: denman Go to Quoted Post
den man,
you posted an initial reply to my question about checking the resistance in the bimetal fuselink. Now I cannot find that response. Where did it go?
#4 Posted : Tuesday, October 2, 2012 4:38:14 PM(UTC)
Sorry but I do not know.
#5 Posted : Wednesday, October 3, 2012 6:24:39 AM(UTC)
Can you please repeat that first recommendation that you made? I believe I recall that you said to check the resistance across the the Thermal Fuse, Item Number AP4423189 / Manufacturer's Number W10258275 by Whirlpool. I believe you said it should be 0 ohms. Is that correct? Any special tips in doing this?
#6 Posted : Wednesday, October 3, 2012 7:36:45 AM(UTC)
Since you have lights the fuse will be OK.
It is Item 6 in Section 1 of the parts if you look at the wiring diagram it kills all power to the control board.
#7 Posted : Thursday, October 4, 2012 9:48:58 AM(UTC)
D-u-h-h-h, on my part. Thanks for calling that to my attention. Also, I just now saw where you had attached the tech sheet. I just printed it out. As soon as I find my magnifying glass for these old eyes, I'll start the process. Thanks again, I'll keep you posted. Wish me luck.
KitchenAid Dishwasher cycle taking a long time (Dishwasher Repair)
by TWash1 9/11/2018 3:11:11 PM(UTC)
by TWash1 9/11/2018 3:10:38 PM(UTC)
Kitchenaid dishwasher (Dishwasher Repair)
by brasilmom1 3/27/2017 6:06:45 AM(UTC)
kitchenaid dishwasher no start (Dishwasher Repair)
by jr1397 3/11/2017 10:52:29 AM(UTC)
Kitchenaid dishwasher leaking under door (Dishwasher Repair)
by chasethedream 1/1/2017 11:30:50 AM(UTC)
KitchenAid Dishwasher Control Board Advice (Dishwasher Repair)
by platypie 11/28/2016 2:37:12 PM(UTC)
year 2000 KitchenAid dishwasher doesn't drain at all (Dishwasher Repair)
by miksem 9/28/2016 12:12:15 AM(UTC)
KitchenAid Dishwasher Clean light blinking twice, totally locked out (Dishwasher Repair)
by hermitnerd 7/13/2016 1:48:37 PM(UTC)
KitchenAid Dishwasher Won't Reset (Dishwasher Repair)
by keiser 1/30/2016 11:43:40 AM(UTC)
Kitchenaid dishwasher not draining... (Dishwasher Repair)
by mjl1297 1/19/2016 10:03:55 PM(UTC)
Kitchenaid Dishwasher soap dispenser won't open during cycle (Dishwasher Repair)
by dawnbeaufort@gmail.com 12/18/2015 6:22:47 PM(UTC)
Kitchenaid Dishwasher Not Spraying Water (Dishwasher Repair)
by chip1998 12/14/2015 9:18:39 AM(UTC)
Kitchenaid Dishwasher Leaks at Float (Dishwasher Repair)
by macd2x 11/8/2015 10:29:26 AM(UTC)
Kitchenaid Dishwasher Redepositing Food (Dishwasher Repair)
by diyindux 11/5/2015 7:39:33 AM(UTC)
Kitchenaid dishwasher leaking (Dishwasher Repair)
by steve80124 9/21/2015 5:15:04 PM(UTC)
