my whirlpool gas dryer heats up for about 30 seconds then goes out.I replaced the coils,the igniter is working, is there another partthat i should check?
Groups: APP Team
Hi.
If your dryer short cycles but still heating check for the restriction in the vent hose or the dryer itself. The simple way of checking the vent is to disconnect it from the dryer and let it run for one load. If it's drying OK - then you have clogged vent.
Post the results.
Simon.
