jhj561
#1 Posted : Saturday, August 25, 2012 10:44:31 AM(UTC)
jhj561
[FONT=Calibri","sans-serif]Hi, my name is Jay. Ihave a kitchenaid kssc42qks00. While checking my ice maker I accidentlyshorted the wrong terminals to start the ice maker cycle. (I previouslydiscovered an always open thermostat in ice maker). Now I have no power to icemaker. Thermal fuse is good, there is no power before thermal fuse. The waterdispenser and ice dispenser work and the lights all work. Everything else worksgreat. I check the wiring diagram that came with the frig and it looks likepower comes from terminal #5 (LB/BL) on the control board but that also powersthe water and ice dispenser, they work so I’m thinking the electronic controlis OK. Any help would be greatly appreciated[/FONT]
jhj561
#2 Posted : Saturday, August 25, 2012 4:31:07 PM(UTC)
jhj561
the wiring diagram that came with the frig is incorrect. I found the correct one online from whirlpool. the problem was on the main control board. I could see where the circuit was fried (open circuit) on the printed circuit board.(see attachment) I was able to solder a wire over it to repair the open circuit.
jhj561 attached the following image(s):
No power to ice maker (Refrigerator & Freezer Repair)
by BradC257 7/21/2018 9:32:03 PM(UTC)
by Jwagner45 11/25/2011 6:37:24 AM(UTC)
No Power To Ice Maker (Refrigerator & Freezer Repair)
by lobhob 7/14/2011 1:58:47 PM(UTC)
by aleope 11/9/2010 1:21:06 PM(UTC)
No power to Ice maker (Refrigerator & Freezer Repair)
by Todd DeForest 10/12/2009 9:51:43 AM(UTC)
