BradC257
#1 Posted : Saturday, July 21, 2018 9:32:03 PM(UTC)
BradC257
Our ice maker quit making ice last year, at the time I removed and replaced the motor board, still no ice. Fast forward to this year, I tried to repair this ice maker learning on the way. The IR Tx board LED seemed dim (using the camera on your phone) so I replaced the board, still won't work. So I replaced the RX board, still no ice. Then I probed the ice maker for voltage, I found some 118vac. Anyways I learned a bunch, where to jump and what to test. I jumped for water, that worked, jumped for motor power N to M, got nothing, motor wouldn't turn on. So I rechecked my power at the ice maker harness. Between the black (hot) and the white (neutral) I got 49vac. I checked the door switch for cont. that checked ok. So am I looking at a main control board replacement? Or is there another rout/ check I can do?
Thanks!
- Brad
ohm
#2 Posted : Sunday, July 22, 2018 9:08:18 AM(UTC)
ohm
Was thanked: 5 time(s) in 5 post(s)
Here is some information for your model.Icemaker should be replaced not repaired.
BradC257
#3 Posted : Sunday, July 22, 2018 10:01:13 AM(UTC)
BradC257
Ahh great! I will preform the diagnostics for the bin eye and ohm out the neutral wire
BradC257
#4 Posted : Sunday, July 22, 2018 1:03:48 PM(UTC)
BradC257
Ok, I went through the diag and checked the ice bin status, that checked as empty. I checked for power at the connector under the fridge, that checked ok for power when the door switch was closed. So it looks like I have a broken neutral wire in the freezer door. :(
And I found the tec sheet for the ice maker in the evap cover. LOL
Thanks again for your help ohm
no power to ice maker (Refrigerator & Freezer Repair)
by jhj561 8/25/2012 10:44:31 AM(UTC)
No power to ice maker (Refrigerator & Freezer Repair)
by Jwagner45 11/25/2011 6:37:24 AM(UTC)
No Power To Ice Maker (Refrigerator & Freezer Repair)
by lobhob 7/14/2011 1:58:47 PM(UTC)
by aleope 11/9/2010 1:21:06 PM(UTC)
No power to Ice maker (Refrigerator & Freezer Repair)
by Todd DeForest 10/12/2009 9:51:43 AM(UTC)
