jfitco
#1 Posted : Sunday, September 20, 2009 3:46:38 PM(UTC)
jfitco
when we pushed the start button it made a noise. then stopped working completely, i checked the contact knob on the dryer and it is clicking okay. power is fine to the dryer. this is a stacked washer dryer unit
ApplianceJunk
#2 Posted : Sunday, September 20, 2009 4:43:35 PM(UTC)
ApplianceJunk
Check the broken belt switch.
Part Details - WHIRLPOOL Broken belt switch, part number: AP3094230
On your model dryer when the belt brakes it trips a switch near the belt idler.
ApplianceJunk
#3 Posted : Sunday, September 20, 2009 4:44:54 PM(UTC)
ApplianceJunk
The switch is #4 in the diagram.
UserPostedImage
jfitco
#4 Posted : Sunday, September 20, 2009 5:09:47 PM(UTC)
jfitco
It sounded electrical when i pushed the start buttom. a little like a contact problem
ApplianceJunk
#5 Posted : Sunday, September 20, 2009 5:15:12 PM(UTC)
ApplianceJunk
So you checked the belt and it was fine?
jfitco
#6 Posted : Sunday, September 20, 2009 5:20:54 PM(UTC)
jfitco
I will need tocheck in the am it is too dark to work in the area.t just did not sound like a belt
ApplianceJunk
#7 Posted : Sunday, September 20, 2009 5:23:17 PM(UTC)
ApplianceJunk
Remove panel #27 in the driagram by removing the three (#47) screws.
You will be able to look behind the panel and see the belt around the drum, unless it's broken, then it maybe on the bottom.
jfitco
#8 Posted : Tuesday, September 22, 2009 12:57:04 PM(UTC)
jfitco
the belt checked out fine. I am wondering if is the motor
Amana electric dryer not working (Dryer Repair)
by Guest 5/3/2024 10:43:01 AM(UTC)
Kenmore Elite Electric Dryer not working (Dryer Repair)
by Guest 7/24/2022 7:10:35 AM(UTC)
GE Dryer Not Working (Dryer Repair)
by DWMarsh 4/14/2020 2:43:03 PM(UTC)
Gas dryer not working properly after power outage (Dryer Repair)
by Frazierfam5 3/7/2016 4:43:32 PM(UTC)
by Cynthia Sosa 9/25/2015 7:00:01 AM(UTC)
Maytag Bravos Electric dryer not working after Power failure (Dryer Repair)
by JohannesB 6/29/2015 3:16:19 AM(UTC)
by cubbiesbp 3/11/2015 1:02:55 PM(UTC)
dryer not working on timed cycle (Dryer Repair)
by kwikk4 2/23/2015 7:53:40 AM(UTC)
Dryer not working properly (Dryer Repair)
by gdmcc1955 8/5/2014 9:59:33 AM(UTC)
by Vitocar 6/17/2014 11:12:39 AM(UTC)
dryer not working (surprise!) (Dryer Repair)
by thebrokenwhirlpool 3/8/2014 11:26:54 AM(UTC)
Dryer not working right (Dryer Repair)
by Monsters 10/1/2013 6:59:17 PM(UTC)
Kenmore dryer not working (Dryer Repair)
by JuanY 5/21/2013 8:57:38 AM(UTC)
Roper dryer not working in auto sense mode. (Dryer Repair)
by CWeasel 7/15/2012 10:03:37 AM(UTC)
by redrider65 2/20/2012 1:25:39 PM(UTC)
