jfitco
#1 Posted : Sunday, September 20, 2009 6:46:38 PM(UTC)
jfitco
when we pushed the start button it made a noise. then stopped working completely, i checked the contact knob on the dryer and it is clicking okay. power is fine to the dryer. this is a stacked washer dryer unit
ApplianceJunk
#2 Posted : Sunday, September 20, 2009 7:43:35 PM(UTC)
ApplianceJunk
Check the broken belt switch.
Part Details - WHIRLPOOL Broken belt switch, part number: AP3094230
On your model dryer when the belt brakes it trips a switch near the belt idler.
ApplianceJunk
#3 Posted : Sunday, September 20, 2009 7:44:54 PM(UTC)
ApplianceJunk
The switch is #4 in the diagram.
UserPostedImage
jfitco
#4 Posted : Sunday, September 20, 2009 8:09:47 PM(UTC)
jfitco
It sounded electrical when i pushed the start buttom. a little like a contact problem
ApplianceJunk
#5 Posted : Sunday, September 20, 2009 8:15:12 PM(UTC)
ApplianceJunk
So you checked the belt and it was fine?
jfitco
#6 Posted : Sunday, September 20, 2009 8:20:54 PM(UTC)
jfitco
I will need tocheck in the am it is too dark to work in the area.t just did not sound like a belt
ApplianceJunk
#7 Posted : Sunday, September 20, 2009 8:23:17 PM(UTC)
ApplianceJunk
Remove panel #27 in the driagram by removing the three (#47) screws.
You will be able to look behind the panel and see the belt around the drum, unless it's broken, then it maybe on the bottom.
jfitco
#8 Posted : Tuesday, September 22, 2009 3:57:04 PM(UTC)
jfitco
the belt checked out fine. I am wondering if is the motor
Gas dryer not working properly after power outage (Dryer Repair)
by Frazierfam5 3/7/2016 7:43:32 PM(UTC)
Dryer not working (Dryer Repair)
by Cynthia Sosa 9/25/2015 10:00:01 AM(UTC)
Maytag Bravos Electric dryer not working after Power failure (Dryer Repair)
by JohannesB 6/29/2015 6:16:19 AM(UTC)
Dryer Not Working (Dryer Repair)
by cubbiesbp 3/11/2015 4:02:55 PM(UTC)
dryer not working on timed cycle (Dryer Repair)
by kwikk4 2/23/2015 10:53:40 AM(UTC)
Dryer not working properly (Dryer Repair)
by gdmcc1955 8/5/2014 12:59:33 PM(UTC)
by Vitocar 6/17/2014 2:12:39 PM(UTC)
dryer not working (surprise!) (Dryer Repair)
by thebrokenwhirlpool 3/8/2014 2:26:54 PM(UTC)
Dryer not working right (Dryer Repair)
by Monsters 10/1/2013 9:59:17 PM(UTC)
Kenmore dryer not working (Dryer Repair)
by JuanY 5/21/2013 11:57:38 AM(UTC)
Roper dryer not working in auto sense mode. (Dryer Repair)
by CWeasel 7/15/2012 1:03:37 PM(UTC)
by redrider65 2/20/2012 4:25:39 PM(UTC)
Kenmore Gas Dryer Not Working (Dryer Repair)
by silverevo05 2/13/2012 12:08:27 PM(UTC)
by sol68 12/30/2011 9:35:12 PM(UTC)
Roper Dryer Not Working (Dryer Repair)
by venkman 11/19/2011 10:03:13 AM(UTC)
