I first had a F-2 code and beeping sound. no oven temp or broil temp will work. I reset the breaker the temp came on for a little bit then went back to F-2 code and beeping had to reset again to stop beeping now it shows F-3 and beeping. Do you sell the oven sensor for my model. I really do not now how old this stove is.
Groups: APP Team
Hi. This is the oven sensor you requested Part number: 12001656
But before buying it check the old one first. Use the multimeter set to continuity 10 Kohm. The resistance of the sensor at room temperature should be around 1100 ohm. If it's bad - replace it. If not - then it's a control board which is no longer available. Thank you. Simon.
