Kathyl
#1 Posted : Thursday, August 16, 2012 12:37:36 PM(UTC)
Kathyl
I first had a F-2 code and beeping sound. no oven temp or broil temp will work. I reset the breaker the temp came on for a little bit then went back to F-2 code and beeping had to reset again to stop beeping now it shows F-3 and beeping. Do you sell the oven sensor for my model. I really do not now how old this stove is.
Simon / APP Team
#2 Posted : Thursday, August 16, 2012 2:59:28 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
This is the oven sensor you requested
Part number: 12001656
But before buying it check the old one first.
Use the multimeter set to continuity 10 Kohm. The resistance of the sensor at room temperature should be around 1100 ohm. If it's bad - replace it.
If not - then it's a control board which is no longer available.
Thank you.
Simon.
Guest (4)
Oven Sensor Replacement (Oven Repair (including Ranges and Cooktops))
by jscuozzo 11/19/2013 4:46:17 PM(UTC)
faulty oven sensor ????? (Oven Repair (including Ranges and Cooktops))
by Orlando8 6/16/2013 10:54:59 AM(UTC)
Oven Sensor Issue (Oven Repair (including Ranges and Cooktops))
by epic1231 10/28/2012 2:40:48 PM(UTC)
replace oven sensor whirlpool (Oven Repair (including Ranges and Cooktops))
by vaught 4/26/2012 8:04:50 AM(UTC)
oven sensor (Oven Repair (including Ranges and Cooktops))
by tompar5 1/17/2012 11:52:38 AM(UTC)
Stumped! Replaced Oven Sensor, Still Not Working! (Oven Repair (including Ranges and Cooktops))
by Debelli 12/4/2010 11:13:00 AM(UTC)
Need new Oven Sensor (Oven Repair (including Ranges and Cooktops))
by lynnie 11/24/2009 5:01:03 PM(UTC)
Checking the oven sensor resistance (Oven Repair (including Ranges and Cooktops))
by Joe the fixer 10/29/2009 10:08:51 PM(UTC)
Show Me How to replace Jenn-air oven sensor (Oven Repair (including Ranges and Cooktops))
by shokwaves 10/26/2009 2:15:46 AM(UTC)
Testing an Oven Sensor (Refrigerator & Freezer Repair)
by shokwaves 10/7/2009 1:47:46 AM(UTC)
Jenn Aire WG30100 oven sensor replacement (Oven Repair (including Ranges and Cooktops))
by szyglowicz 9/9/2009 4:55:50 AM(UTC)
How to replace oven sensor? (Oven Repair (including Ranges and Cooktops))
by donsmullen 7/11/2009 10:14:14 AM(UTC)
by Warren F-150 5/28/2009 7:15:49 AM(UTC)
How do you replace an oven sensor? (Oven Repair (including Ranges and Cooktops))
by kschrei 5/28/2009 4:39:22 AM(UTC)
F3 on Frigidaire after replacing oven sensor (Oven Repair (including Ranges and Cooktops))
by undercookedinPDX 11/27/2008 11:29:54 AM(UTC)
